Dash was replaced, having electrical issues
Old Aug 20, 2009 | 11:23 AM
blk93civic's Avatar
Default Dash was replaced, having electrical issues
I bought my civic a few months back and the guy I bought it from said the blinker was out on the driver side. I went ahead and bought the car because it didnt seem like a big deal, well what i found to be was the entire dash electrical system has issues. When i turn on the harzards all my dummy lights flash with it and if the wipers are on they pulse with the flashers. I have no clue where to begin. I replaced the pig tail on the brakes and checked the bulb in the cluster and nothing. Also the odometer and trip meter are inop as well. Can someone help me out.
Old Aug 21, 2009 | 03:11 AM
welcome to the forum, Need to try to get as much info on the car from the guy you bought it from, get a wire diagram for your car, and start from the easiest point. Also check to see if all the wire harness are clean and secured at the connections. fire wall connections do get loose. Also there may be Hot wire on wire that has burnt through.
( Had a RoadRunner that dimmed my lights when I turned on my my blinkers, found in the wire harness the hot line melted through and shorted the other wires. )
Old Sep 1, 2009 | 06:22 AM
smithteddy123's Avatar
you have done a wrong thing.when someone had told you beforehand you could have gone and checked it.anyways now when you have it i think the whole problem is with your dash board electricals.get it replaced.
endlesstricks
Oct 25, 2012 03:04 PM
endlesstricks
Sep 25, 2012 03:30 PM
bobhody
Jul 23, 2008 07:03 PM
jsw1208
Sep 27, 2006 08:13 PM
