del Sol won't start intermitantly
Old Jan 16, 2010 | 04:51 PM
wayne0's Avatar
Member
Default del Sol won't start intermitantly
My '94 del Sol SI will not start once in a while. Cranks fine, but won't fire.
Go back later and it starts right up.(sometimes) Always happens cold.
Any ideas?
Old Jan 18, 2010 | 12:27 AM
spark plugs, wires, compression, relay, ignitor, distributor.
Old Jan 18, 2010 | 06:45 PM
wayne0's Avatar
Member
New wires and plugs.Good compression. What relay? Ignitor? What's that? New name for the ignition coil?
Wondering if it could be a fuel issue.
Old Jan 20, 2010 | 02:59 AM
main relay, and yes ignition coil. and yes could be fuel, check your fuel rail to see what pressure you have if any.
Old Jan 25, 2010 | 06:36 PM
wayne0's Avatar
Member
Default Boy, is my face red!
Frozen fuel line! Drygas solved the problem. Never had a problem with this in 30+ years!
Old Jan 27, 2010 | 03:44 AM
might be all the junk they are putting in the fuel, or lots of moisture getting into the tank. Thanks for the find and fix.
Chris Skoglun
Jun 27, 2016 06:46 PM
GRN-BNDT
Jul 29, 2015 06:54 PM
volcomxyz
Aug 25, 2010 03:34 AM
Redcoats19760
Mar 28, 2006 03:03 PM
ones102envy
Dec 23, 2005 02:43 PM
