Electrical Problem
Electrical Problem
ok so my alternator is not charging my battery. Went and had alternator tested twice and the alternator is fine. I pulled the ground cable off the battery when the car was running and the car died instantly. I checked the plug that goes into the alt. and that is fine and clean. I dont know what else to check and am completely stumped. its a h22a in a 96 civic coupe btw.
Electrical Problem
I have a problem with my car, my brake lights doesnt work. I checked the bulbs, fuses relays and brake switch. it seems to be working fine. what is the problem? any experience?Thanks for your help. _______=== XRumer 5.0 Palladium RULEZ! ===
Electrical Problem
I got the same problem, after a month...but I charged it the opposite way....I mean through the mains, when it was there for 4 hrs and still not going to get turned on I tried the usb cable, PC found there is nokia on USB, but PC Suite found nothing this time. Display dead. Going to ask for replacement.
