Electrical Problem
Old May 14, 2009 | 06:05 PM
timaye's Avatar
Exclamation Electrical Problem
ok so my alternator is not charging my battery. Went and had alternator tested twice and the alternator is fine. I pulled the ground cable off the battery when the car was running and the car died instantly. I checked the plug that goes into the alt. and that is fine and clean. I dont know what else to check and am completely stumped. its a h22a in a 96 civic coupe btw.
Old May 15, 2009 | 11:38 PM
welcome to the forum. Did you check the condition of your battery while you tested the alternator. have you done a load test to prove the battery is good.
Old May 29, 2009 | 03:40 PM
MagicOPromotion's Avatar
Default Electrical Problem
I have a problem with my car, my brake lights doesnt work. I checked the bulbs, fuses relays and brake switch. it seems to be working fine. what is the problem? any experience?Thanks for your help. _______=== XRumer 5.0 Palladium RULEZ! ===
Old May 29, 2009 | 05:08 PM
check for good ground.
Old Jun 11, 2009 | 09:02 PM
Igorokk's Avatar
I got the same problem, after a month...but I charged it the opposite way....I mean through the mains, when it was there for 4 hrs and still not going to get turned on I tried the usb cable, PC found there is nokia on USB, but PC Suite found nothing this time. Display dead. Going to ask for replacement.
Old Jun 12, 2009 | 05:41 PM
Igorokk welcome to the forum, what are you talking about? Please explain how a USB with nokia is going to help fix a none charging alternator on a honda??? Thank you
mr green
Mar 17, 2012 06:59 PM
orion681
Feb 19, 2009 11:00 AM
ksturgio
Nov 24, 2008 01:06 PM
Fire
Jul 22, 2006 07:26 PM
klholder
Jun 30, 2006 11:33 AM
