Electrical System Failure?
Old 08-20-2006 | 12:23 AM
artist118's Avatar
Default Electrical System Failure?
Alright, I have a question that may be very simple.
I am getting power supply, but I can not start the car. When I do turn the key all my electrical units start clicking (door locks, gauges, and whatever else). I am thinking this is due to a bad alternator, but something seems worse than just a faulty alternator. Anyone have any ideas on what this can be?
-curt
Old 08-29-2006 | 01:31 PM
golfer's Avatar
Default RE: Electrical System Failure?
ORIGINAL: artist118
Alright, I have a question that may be very simple.-curt
Where are you checking for this , at the battery ??
Just because there may be 12 volts there may not be enough cranking amps to start the car.
Since you say the car won't start the alternater really doesn't come into play. Until the car is running everything is powered by the battery only.
Have your battery checked ( load tested ) and if it's bad replace it. If the battery is not being charged while running , then you can say you have a bad alternater.
Mfsmith
07-05-2012 08:21 AM
Rfry2010
07-27-2010 09:24 PM
jsw1208
09-27-2006 09:13 PM
Fire
07-22-2006 08:26 PM
klholder
06-30-2006 12:33 PM
