Failed smog test 25 BTDC
Old Jun 24, 2013 | 09:30 PM
Hermean93's Avatar
Question Failed smog test 25 BTDC
I have a 94 Accord a friend brought to me he failed smog test the print out says fail - Ignition Timing:25 BTDC
Does this mean i need to advance my timing?
Or do i need to get to the timing belt and put the cam shaft an crank shaft back on marks?
He had his timing belt replaced recently and since then the car hasent been running rite?
Its a 94 Accord EX 2.2 V-tech
Any help would be appriceated thank you!
Old Jun 29, 2013 | 12:23 AM
driveability's Avatar
Would be best to post the actual printout. The 25 BTDC sounds like a misprint, not a honda expert but do have a CA. Test and repair (smog) license. Will the engine run & drive set there ? Post the details. I'v seen people retard the timing to lower the numbers but this sounds wrong to me. Details needed.
Chris Pickett
May 31, 2023 02:45 PM
pergojr
Aug 16, 2013 03:59 PM
grantlyn513
Feb 20, 2013 08:14 AM
jeromek
Feb 1, 2009 03:02 PM
Herbie
Nov 2, 2006 03:26 PM
