Help
Signal lights stopped working. Replaced flasher, continuity with all 4 bulbs , fuses all ok. Anyone have a similar issue? Presently checking all grounds(wires). 2010 Honda SH150i
On a multi tester current is good between flasher blinker connector and each of the four individual bulbs.
Current is good? How did you measure the current? If there's current the bulbs will be lit.
My friend's multitester with an audible signal to each signal light socket. Bulbs did not light. Signal light blinker does make a clicking noise when button is pressed. I clean the button/switch and greased it with dialectic grease as well.
That tells me nothing. I don't think I can help you.
