Help
Old May 21, 2023 | 07:56 AM
Paddys49's Avatar
Default Help
Signal lights stopped working. Replaced flasher, continuity with all 4 bulbs , fuses all ok. Anyone have a similar issue? Presently checking all grounds(wires). 2010 Honda SH150i
Old May 21, 2023 | 06:53 PM
Seems everything is fine unless it's not. What does continuity of all 4 bulbs mean?
Old May 22, 2023 | 04:47 PM
might check the emergency flasher push button , older honda's the wiring went through the emergency flasher push button.
Old May 23, 2023 | 06:23 AM
Paddys49's Avatar
On a multi tester current is good between flasher blinker connector and each of the four individual bulbs.
Old May 23, 2023 | 09:09 AM
Current is good? How did you measure the current? If there's current the bulbs will be lit.
Old May 23, 2023 | 11:52 AM
Paddys49's Avatar
My friend's multitester with an audible signal to each signal light socket. Bulbs did not light. Signal light blinker does make a clicking noise when button is pressed. I clean the button/switch and greased it with dialectic grease as well.
Old May 23, 2023 | 04:45 PM
That tells me nothing. I don't think I can help you.
Usen
Jul 10, 2021 12:02 PM
blondewind
Feb 16, 2021 04:33 PM
technotrevor
Feb 21, 2016 09:04 AM
RedCivic01
Apr 21, 2013 01:28 PM
jfred6
Dec 23, 2009 04:15 AM
