Help with Flashing D Indicator on dash
Old May 19, 2023 | 07:31 AM
valentino26's Avatar
Default Help with Flashing D Indicator on dash
Hi All,
Hopefully I can get some advice here.
Model 2007 Honda Crv EXL
Problem: Gear indicator intermittently flashes on dash while driving. (Transmission Fluid level is correct, and fresh)
Car runs and drives as normal but the "D" indicator flashes indicating a transmission issue. No OBD2 codes present for Transmission.
I do have Honda DTC codes:
DTC B1906: Immobilizer-Keyless Control Unit Lost Communication with Gauge Control Module (A/T Message). 1. Clear the DTCs with the HDS.B1008 Honda Possible Causes · Faulty Gauge Control Module · Gauge Control Module harness is open or shorted · Gauge Control Module circuit poor electrical ...
Does anyone have experience with this? I have no idea how to fix the flashing light....
Thanks,
Matt
Old May 19, 2023 | 04:35 PM
You need to scan the TCM. You are scanning the PCM.
Old May 26, 2023 | 09:18 AM
Hi grcauto,
Thanks for the tip on the pcm, I managed to get a better scan tool "Bluedriver" it has picked up a TCM code P0741-02. I understand this is related to the "Torque Converter Clutch Circuit Performance or Stuck Off". I was getting the code as an intermittent flashing D indicator on the dash 2 times. The weird part is the transmission seems to be functioning normal while the code was present. I'm assuming it's operating normal, as on the highway the engine speed was around 2400rpm at 117km/h, no obvious slippage. (I think this is where it normally was before the transmission DTC P0741). I reset the code and it has not come back for a couple days.
I'm debating another fluid flush as a next step, possibly a visit to the dealer to test the TCC solenoid functionality. (A private garage let me know their database mentioned 6 times that this codes solution was a new transmission) As the suv seems to be shifting fine I'm hopeful that is overkill.
Thanks,
Matt
Old May 26, 2023 | 09:50 PM
Look at the freeze frame. See what happened when it set the code. More than likely the only change was in engine speed (rpm) as the converter didn't lock when it should.
harvey2377
Nov 20, 2022 02:02 PM
GaryDZ
Aug 29, 2022 02:29 PM
buddyo5
May 12, 2013 07:56 PM
AdamBaum
Aug 15, 2011 12:59 AM
bobmwn
Sep 9, 2008 01:08 AM
