Help Please
Old May 31, 2007 | 07:30 PM
Jessica's Avatar
Default Help Please
Hey there i have an 89 honda accord. My problem lies in the front left tire. I believe that my ball joint is broken. Would i have to have the pivot arm replaced as well? do you know approx. how much it would cost to replace? Thanks for the help
Old Jul 6, 2007 | 08:54 PM
lavender02's Avatar
Default RE: Help Please
If you suspect that your ball joint is broken let it be checked to your nearest autoshop before further damage may be done. I've done the same when I suspected that my Honda ball joint was brooken last week...Good luck...All the best!
Old Jul 11, 2007 | 02:01 PM
Ball joint cost est 45.00 arm cost 165.00 if the ball joint did not damage the pivot arm, no problem. Ball joint usually destroy only them selves. you have an upper and lower ball joint (Info only)
okhozi
Jan 6, 2010 09:10 AM
nathancrowder
Oct 23, 2008 12:28 AM
91hondaaccord
Jul 21, 2008 05:15 PM
