honda civic power window problem
Hi,
I need some help please!! I got a 97 honda civic, the main control switch (drivers side) won't operate the passengers side window. But it will go up & down with the switch on the passengers side. I tried changing the main switch...still not working...the regulator is fine as it works from the passengers side....why won't it work from the drivers side?? its realli annoying, if any one know a solution, please let me know!! >.< thanks!
check the contacts on the drivers side control module. If you can jump the contacts from the back of the connector and the passenger window goes up or down, youcanblame the module, replace it.If that is the case let me know I have an extra power window control module out of a 98 coup.
4m4s0
Apr 30, 2010 03:38 AM
