Honda CR-V 2002 AC problem
Old May 1, 2023 | 10:02 PM
jean-marc's Avatar
Unhappy Honda CR-V 2002 AC problem
Hi to all ;
AC problem on my CR-V 2002 : When activate AC On : the AC clutch and both fans turns ON for a couple of seconds , then all stop; If I retry immediately : NO start at all ; Fuses , relays, all Ok; Check the refrigerant presuure on LOW side : 85 psi (AC clutch compressor OFF) I am unable to check the pressure when sytem is ON because too short time --. AC clutch does not seems to be size... I wonder : pressure switch or freon pressure too low, or else ...? I think (but i could be wrong ) that there is no Leak of refrigerant . .. I am quite lost on this matter : any help and-or advice will be much appreciated.. Thanks
Old May 2, 2023 | 09:26 AM
85 is to high on the low side.
Old May 3, 2023 | 07:10 PM
jean-marc's Avatar
Value too high even when the compressor OFF ?
I wonder, because to me this looks like a good values : about 85 OFF, 35 PSI about when compressor ON
Old May 4, 2023 | 09:58 AM
35 is OK. Throw a scan tool on it and see what the switches are doing.
Old May 5, 2023 | 08:46 PM
jean-marc's Avatar
Yes I know 35 psi is fine when compressor is ON ; I was referring to the pressure reading when compressor is OFF
Is 85 psi really too high on LOW side when compressor is OFF ? Maybe not...or...
Old May 6, 2023 | 09:55 AM
I take it you don't have a scan tool. You should get one. They cost about the same as 1 to 2 hours of labor and can save you a lot more than that.
rickpaulos
May 16, 2021 05:35 AM
lessonstar
Nov 6, 2017 02:04 AM
Mary Elizabeth Gerber
Oct 15, 2016 06:15 AM
ssal
Sep 23, 2016 10:20 AM
t-dogg
Aug 16, 2009 10:47 AM
