I haven't done any maintence besides oil changes in 20 months
Old Dec 21, 2012 | 01:28 AM
SpaceCoast's Avatar
Default I haven't done any maintence besides oil changes in 20 months
I bought a Honda CRV 09 that was certified in April 2011. So that was about 20 months ago and 10,000 miles ago (45,000 total). Since then, I have only taken it in for oil changes when the indicator is on.
I plan to take the car for 4 new tires as soon as possible. I am also planning on getting a 4 wheel alignment. I always take my car to Honda for the oil changes. Do they check the hoses and belts when they change the oil?
I don't know anything about cars but I am learning now as I realize I have been being irresponsible about it.
I have a coupon for a free inspection:
A trained technician will provide a free, multi-point inspections looking at all your vehicle's major systems including the engine, brakes, drivetrain, suspension and steering components.
So I will have that done as well. What else do I need to have checked?
Thanks.
Old Dec 21, 2012 | 07:38 AM
A good tech will check belts and hoses as well as other fluid levels,you could do a break inspection. But when they mount the new tires they should check that.
Old Dec 21, 2012 | 07:58 AM
welcome to the forum. Yes Honda checks hoses and belts when oil is changed. They also charge a lot for tires. If you have an Americas Tires or Discount Tires, it costs less. Wheel alighnment is done normally 1x a year. you might shop around on costs. Airfilter change is about 12k-20k depending on the air quality. In Ca. 15k the filter is quite dirty. If you have an automatic, the fluid can be changed.
Old Dec 21, 2012 | 09:43 AM
SpaceCoast's Avatar
When Honda certified the vehicle in 2011, do they replace the fluids or do they just check that they did not need to be replaced at the time of inspection? Should I just pay attention/trust the maintenance minder when it comes to changing the fluids or should I be more proactive?
And by Air filter, you mean for the car's air condition filter?
Thanks again.
Old Dec 21, 2012 | 07:17 PM
lowlife9's Avatar
im going to say when it comes to car dealers there only as good as the mechanics they employ. i worked for the largest toyota dealer in connecticut for years. the one mechanic in charge of toyotas "certified" used car inspections would literally kick the the tires and do a 15 minute visual inspection no test drive or anything and this guy was there head mechanic. i got into a fight with this guy one day when a family came in and bought a used mini van and let them leave with four severely dry rotted tires. i made them come back and have the tires replaced. i was pisst to say the least.
Old Dec 23, 2012 | 06:56 AM
Sadly,I have seen this type of thing happen more often now that dealers care more about the holy dollar than they do about customer care,you have to be your own safety net these days,or find a mechanic you can truly trust.
Old Jan 1, 2013 | 11:47 PM
sonda's Avatar
totaly true.... and as well as dnt forget to change DPSF. duel pump system fluid. its the differential fluid. MUST use genuine oil.
CarlaMasterson
Oct 23, 2009 02:48 AM
andrewtp
Mar 31, 2009 08:42 PM
Vizard
Mar 23, 2009 04:29 PM
illcar
Jan 11, 2009 04:19 PM
94hndaccordracing
Oct 16, 2007 01:22 AM
