Ignition key stuck
Ignition key stuck
Hi everybody,
The ignition key got stuck in the lock after switching off the engine...and stayed there even after several times of starting and switching off the engine... gear in P.
(Civic 4-door 2003 1,6 automatic)
Any hints what to do ??
Thanks in advance,
Thanks in advance,
Had this issue before. Fixed
Hey there, sorry to hear about your issue. I had the same problem on a 04 civic. I had to remove the entire ignition switch that is attached to the sensor module. I had to remove the plastic covers around the steering wheel.. There were two rounded off bolts that I had to remove using a hammer,chisel, and bought some Irving Bolt extractors.
Bolt Extractors - Tools - IRWIN TOOLS
I then took it to a Key Smith who only charged $40 dollars to replace the Tumblers inside they ignition switch that were damaged.
I found replacement bolts at home depot.
Saved me having to tow the car to the dealer and spending some serious cash!
Hope all this information is helpful!
