Ignition key stuck
Old Apr 2, 2015 | 08:52 AM
jackraider's Avatar
Default Ignition key stuck
Hi everybody,
The ignition key got stuck in the lock after switching off the engine...and stayed there even after several times of starting and switching off the engine... gear in P.
(Civic 4-door 2003 1,6 automatic)
Any hints what to do ??
Thanks in advance,
Old Apr 3, 2015 | 03:56 AM
possible change of the ingnition switch.
Old Apr 25, 2015 | 07:28 PM
Take a hammer and lightly tap the end of the key while in the off position,i know that usually works for a key stuck in a door cylinder. Just tap lightly.
Old May 17, 2015 | 05:01 PM
crunkwizard's Avatar
Smile Had this issue before. Fixed
Hey there, sorry to hear about your issue. I had the same problem on a 04 civic. I had to remove the entire ignition switch that is attached to the sensor module. I had to remove the plastic covers around the steering wheel.. There were two rounded off bolts that I had to remove using a hammer,chisel, and bought some Irving Bolt extractors.
Bolt Extractors - Tools - IRWIN TOOLS
I then took it to a Key Smith who only charged $40 dollars to replace the Tumblers inside they ignition switch that were damaged.
I found replacement bolts at home depot.
Saved me having to tow the car to the dealer and spending some serious cash!
Hope all this information is helpful!
Old May 17, 2015 | 05:20 PM
Welcome in,thanks for the advice.
realdanmiller
Jun 30, 2009 06:10 PM
ronnieboy
Mar 16, 2009 09:37 PM
Dave2
May 26, 2008 04:03 PM
derek123
Nov 26, 2006 07:31 PM
Hannu
Sep 28, 2006 02:43 PM
