Ignition lock problem
Old Jan 18, 2013 | 02:51 AM
viGeflafed's Avatar
Default Ignition lock problem
I’m having Honda odyssey 2005 model and having the problem with the ignition lock. The key hardly going inside the lock and if it goes inside the car doesn’t start. Don’t know what could be the problem for this and how much it will going to cost for the repair. anybody suggest me some cheap locksmiths it will helpful for me.
Old Jan 18, 2013 | 10:05 AM
welcome in,replace the ignition switch yourself,not that hard.
Open the fuse panel cover and remove the electrical plug that is plugged into the fuse box which powers the ignition switch. The ignition switch power connector runs from the fuse panel back to the ignition switch. Verify that you have the correct plug and wire by tracing the wire back to the steering column.
Remove the two screws on the underside of the steering column that hold the cover panel in place. This panel covers the access to the ignition switch.
remove the two bolts holding the ignition switch in place. Some Honda vehicles have blank head bolts or round head bolts. In this case, you will need to cut a groove into the center of the bolt head with a dremel and use a flat tip screwdriver to remove the bolt. Or you can try removing the bolt using a center punch and a hammer to turn the screw bolt counterclockwise.
Pull the ignition switch out of the steering column and install the new switch. Installation is the reverse of removal. Tighten the ignition switch retaining screws by hand.
Old Jan 18, 2013 | 06:30 PM
RMDaccord 09's Avatar
My 09 accord won't start I morning only had it checked by Honda dealer and no diagnosis was able to be found. It makes no noises at all when I insert key just won't turn over almost feels like the key or ignition. Dealers mechanic says he 90percent sure it's the starter I have a video of me trying to start it but I cant upload it from this email address Can anyone help
Old Nov 14, 2014 | 12:35 PM
Keyspecialist's Avatar
Default Honda Ignition Lock Problem
Here's the breakdown on your problem with your key not turning in the ignition lock. What I have found while fixing this type of problem.
(1) Your key wears down & allows the wafers(tumblers) to move past the stopping point & starts to bend on the inside of the lock. That's why somewhere in time it was hard for you to turn, eventually got worse & stopped working. Most people deal with this problem for days or weeks until they are stranded because they don't know the symptoms of this problem.
(2) The only solution is to have it replaced or rebuilt. But, the problem with replacing it with a new one is the keys to the ignition with be different from the rest of the vehicle & needs to be programmed. Also, if you ever loose your keys your local dealer will not be able to cut a key to the ignition because it was changed. So guess what another new lock at this point & with luck the local dealer will have one in stock & can squeeze you in. Hopefully you are not on vacation.
(3) A better solution would be to have someone rebuild the lock with new parts so you can maintain a 1 key system for the whole vehicle & cut new keys.
Note: If you are having a problem finding someone certified that you can trust in your area to help you with this problem. People mail me these ignition locks from all over the world to repair them all the time. Just give me a call: 678-699-2634 or website: KeySpecialist.com
darius25
Nov 20, 2012 06:52 PM
Julie Landry
Mar 13, 2012 11:26 AM
96civick
Sep 22, 2011 05:13 PM
89civicsi
Feb 12, 2009 11:59 PM
wannabedivin
Jan 20, 2009 02:57 AM
