Injector Pulse
Old Jun 23, 2013 | 08:11 AM
crx191's Avatar
Default Injector Pulse
Hi guys,
New to the forum as I've just got a CRX-DelSol - UKspec.
Had the car a few days and it developed some interesting electrical faults preventing car from starting....
The car cranks, but doesnt fire.
  • The engine will fire on aerostart, but then dies.
  • It has good, constant spark.
  • Fuel pump runs.
  • Injectors have power (noid light tested, light stays on when cranking)
  • ECU is fine, tried a replacement.
  • ECU grounds are fine, ran them again just to be sure.
  • Continuity to injectors from ECU is fine.
  • Battery and fuel levels are ok.
The symptom essentially is no injector pulse to ground the injectors...
I've tried everything I can think of to get it to fire, but it still wont have it. I'm this close to burning the fu*ker at this point.
Does anyone have any ideas? - I was thinking possibly the Crank position sensor, but I'm not sure how to test it.
Taylor_green
Oct 6, 2014 10:43 AM
Joe Bertschinger
Jul 27, 2013 02:12 PM
mftsc40
Jul 21, 2010 07:46 PM
