ls vtec nisfired then shut off.
Old Mar 14, 2009 | 03:00 PM
alexkinsley's Avatar
Default ls vtec nisfired then shut off.
i just put a new cap n rotor on my b18c1 block b16 head. and that didnt help im pretty sure its notgettin spark. im ordering a distributor today. am i missing something? when it was running it would bog only sometimes for around 3 seconds then i could rip on it n it ran fine
Old Mar 14, 2009 | 06:54 PM
welcome to the forum. If your timing belt did not break or slip, the coil/ignitor in the distributor may be bad. Also check to see if you have fuel pressure at your fuel rail.
Old Mar 14, 2009 | 09:55 PM
well i replaced the distributor cap n rotor and it wont spark on the 3rd cylinder even with new plugs. i dont get it
Old Mar 15, 2009 | 03:00 PM
if you are getting spark on 1,2 and 4 and not on 3, it could be your plug wire is shorted.
Old Mar 16, 2009 | 12:20 PM
i put 3 sets of wires on it. i checked for compression just to be sure thats fine. should i take back my distributor n get a new one?
Old Mar 16, 2009 | 11:34 PM
try taking an ohm meter and see if there is continuity from the inside of the distributor to the topside. Also did you try swapping the spark plug for check out purpose.
Old Mar 17, 2009 | 09:52 AM
ya i put 2 new spark plugs just to make sure but ill have to find an ohm meter to try that
Old Mar 17, 2009 | 12:26 PM
if your spark plug is known good, the wires known good, then there is no spark coming out of the distributor on #3 positon, the distributor is shorted or no power coming from the rotor or coil out to the distributor
Old Mar 17, 2009 | 04:03 PM
i know right everything was new so i started over and got another new distributor and it worked so the first new one was bad. thanks alot for your help
Old Mar 18, 2009 | 05:03 AM
  #10
thank you for your response.
thedaveman89
Jan 8, 2009 12:46 PM
colbygfp
Oct 12, 2008 06:39 PM
jordtee
Sep 18, 2008 04:57 AM
dogghoney
May 23, 2008 07:28 AM
mdgttim
Oct 21, 2007 09:30 PM
