Need advice - Stripped manifold/sensor threads
Old Nov 27, 2006 | 08:21 AM
redintex's Avatar
Default Need advice - Stripped manifold/sensor threads
Good morning,
I am new to the forum and have a specific problem that I need some advice to fix:
2001 Honda Accord EX 4cyl Engine code F23A1
Recently started getting Check Engine Light - error code was PO135 - determined need of O2 sensor replacement.
Had the hardest time removing old O2 sensor (one located on exhaust manifold) - I started the car a couple of minutes prior to removal to allow for expansion, etc. as recommended. I had to fight it the entire way off, only to realize when removed that it had apparently been stripped when installed?!? I am the original owner and know that there should have been no reason for removal in the past.
Now to the problem at hand: I now have stripped threads on the exhaust manifold. I suspect that I am getting beyond my capabilities. Is there a way to properly repair this without removal of the manifold? Not trying to be lazy, just don't want to make more work than necessary.
Any advice would be greatly appreciated!!!
usahoe18
Dec 19, 2014 03:28 PM
PartsManTypeR
Oct 6, 2013 08:44 AM
Hondagal1
Sep 20, 2013 11:50 AM
HondaCivic1997L
Nov 25, 2010 09:42 AM
da1ed7
Feb 5, 2009 10:02 PM
