O2 Sensor
Old Mar 18, 2015 | 03:17 PM
jackraider's Avatar
Default O2 Sensor
I have a 98 prelude with stock everything. I was getting a secondary o2 sensor error so I replaced the sensor and reset the computer. The error came back a few miles later. (only the one o2 sensor error code) I used the flow chart in the factory service manual to ohm out the "bad" o2 sensor and it read 16 ohms the range says 10-40 is good. So i continued on and everything lead me to the point to check the wire between #14 ecu (ecm) eat ecu (tcm) curise control and h2os. My question is this. Could it be a bad sensor, or a sensor that the car doesnt "like" ive heard all kinds of theroies about this sensor wont work, that one wont work. I have no idea why there would be a short between the ecu and the eat ecu, my car is a manual and shouldnt have a eat, thats for an automatic transmission.
Old Mar 20, 2015 | 05:19 PM
lowlife9's Avatar
did you buy a off brand sensor from amazon ??? you only use DENSO or NTK in honda's.
Old Jun 2, 2015 | 11:52 AM
usdm's Avatar
If you buy a Spark plug defouler and drill it out to 1/2'' it will push the o2 far enough out of the main stream to get a cleaner reading...3$ fix. Also if you clear the CEL and the code comes on immediately, then you know it's a circuit issue.
Ben
Apr 3, 2007 04:44 AM
chuck norris hx
Nov 30, 2006 10:24 AM
redintex
Nov 27, 2006 08:21 AM
ed1le
Jul 17, 2006 02:00 PM
1998HondaCivic
Jan 20, 2006 02:13 AM
