OVERHEATING!!!! 1996 Honda Accord Lx
Old Aug 28, 2010 | 02:28 PM
Ms_Hannah's Avatar
Question OVERHEATING!!!! 1996 Honda Accord Lx
Someone please help!! My car is overheating and I would like to know what it could be..... I've notice some smoke coming from the Engine area like where the spark plugs are too, and my engine seems to get really hot. I've changed the waterpump and timing belt, the radiator, thermostat, and some hoses. It's still running hot. Also, I had the Head Gasket checked and there's nothing wrong with the head gasket and my oil is not milky. So What could it be??? What do I need to check for now?
Old Sep 10, 2010 | 02:52 AM
welcome to the forum. check the timing of the engine.
Old Sep 25, 2010 | 01:44 AM
Wyman's Avatar
HI
The wrong pump might also cause engine to overheat.Some engines which have serpentine drive belts require a special water pump that turns in the opposite direction of those used on the same engine with v-belts.I suggest you to check the fan ,as most overheating problems are caused by a faulty fan clutch which might reduce the cooling efficiency.
Old Oct 6, 2010 | 02:03 PM
Good info,check to see if the thermostat is opening,I have replaced thermoststs only to find out it was defective. If elec. fans make sure they come on. Let us know what you find out.
Old Oct 10, 2010 | 11:35 PM
benitez63035's Avatar
check and see you have any hoses leaking water, My 90 accord had a tiny whole in a hose and i never knew until it was overheating badly
Illazell
Oct 19, 2010 11:41 AM
illn0tsick
Apr 5, 2010 12:46 AM
infrantry
Mar 30, 2008 05:15 PM
goudge74
Aug 27, 2007 07:59 PM
dougster01
May 29, 2007 07:22 PM
