Radio has nothing but static
Old Jun 16, 2016 | 09:25 AM
fenwayman's Avatar
Angry Radio has nothing but static
My wife has a 2004 Accord LX Sedan. When she turns on the radio all she gets is static. I'm sure speaker connections are good. Any info would be greatly appreciated
Old Jun 17, 2016 | 05:26 AM
welcome the forum. check you antenna connections at the antenna and behind the radio.
Old Jun 21, 2016 | 02:42 PM
lowlife9's Avatar
the car has a powerd antenna located on the rear window. either its not getting a power supply or the line on the window was damaged possibly from having window tints installed. certain window tint film will also interfere with reception. if the radio was working before you installed a new head unit my guess is you didn't connect the power supply back up. your going to need a wire diagram to figure out which one is the correct wire. also do not connect the dimmer switch that could cause severe damage to the electrical system.
James Blevins
Jan 14, 2015 11:06 PM
Raabhimself357
Nov 9, 2010 11:56 PM
toicy4ya
Nov 8, 2010 01:18 PM
jutgin
Jan 20, 2009 08:59 PM
baixin02
Nov 4, 2007 08:15 PM
