Should I patch my windshield or replace it in my case?
Old Jan 6, 2026 | 12:15 AM
theateist's Avatar
Default Should I patch my windshield or replace it in my case?
I’ve seen a lot of videos where people repair different kinds of "spider" cracks in windshields. Would you consider my crack (in the middle of windshield) to be a large one that really requires a full windshield replacement, or is it reasonable to try a DIY repair kit first? My thought is to use a kit initially, and only replace the windshield if the repair doesn’t hold or if the crack grows over time. Does that make sense in my case?
Old Jan 9, 2026 | 08:14 PM
If you can get a vacuum on it (may cause it to grow a little) and suck in super glue from the other side. If it sucks it in it'll keep it from growing when done.
Old Jan 26, 2026 | 08:17 PM
jacobgary's Avatar
Member
Originally Posted by theateist
I’ve seen a lot of videos where people repair different kinds of "spider" cracks in windshields. Would you consider my crack (in the middle of windshield) on my UForce 600 Front Tinted Rear Windshield to be a large one that really requires a full windshield replacement, or is it reasonable to try a DIY repair kit first? My thought is to use a kit initially, and only replace the windshield if the repair doesn’t hold or if the crack grows over time. Does that make sense in my case?
Yes, it makes sense to try a DIY repair kit first, as long as the crack is not too large and you monitor it closely. If it spreads or affects visibility, you’ll need a full windshield replacement.
kccivic
Oct 5, 2025 04:32 PM
WesleyIsMe1
May 14, 2019 07:45 PM
Paul D. Roller
Jan 20, 2017 05:23 PM
jmurphnd
Dec 13, 2013 07:29 AM
robj6767
Jan 27, 2012 10:30 AM
