sudden unintended acceleration problem
Old May 3, 2016 | 10:14 PM
Lenny W Schwartz's Avatar
Default sudden unintended acceleration problem
hi I have a 1914 crv and when I tried to stop the car suddenely sped up and I
had a very hard time getting it to stop....I heard this is a pretty common problem with other make cars..what can I do about it?from the stories ive heard Honda wont do anything about it..what else can I do?
LENNY
Old May 4, 2016 | 06:04 AM
welcome to the forum. How many times has this happen, document this, each time it happens, time of day , everything on record. And have you told your dealership of what happened. also document times called, whom you talked to, date and time and what was said. should anything happen to you or your family or friends, at least you have it documented. it this happens again, and your dealership is of no help, call american honda and get a work order started.
Old May 4, 2016 | 06:43 AM
hi
why wont the dealership help?is it a common problem?any idea why it happens?expensive?thanks for the welcome..
lenny
Old May 4, 2016 | 07:45 AM
todate, I have not heard of a honda doing the Toyota stuck throttle. you are the first on our forum. But documenting the info will make it easier to explain to the dealership of what is going on, they will look into it but if it does not do it with them, they will just say could not duplicate, did not do it as we checked this out. the documentation only assists them what to look for, temp, date, more info the better to find. i did not say the dealership would not help. it is not a common problem, sometimes it happens when the gas and the brake is stepped on at the same time due to the pedals are at the same height. this has happen with big equipment that i've driven.
Old May 5, 2016 | 06:06 PM
Sounds like the throttle body may be sticking,try cleaning it.
jt1163
Aug 24, 2010 06:32 AM
jgelis
Jan 31, 2010 02:13 PM
paulr0859
Aug 22, 2007 03:03 AM
Koras
Jun 14, 2007 05:31 AM
mattsthru
May 27, 2007 07:15 PM
