tail light problem please help
Old Apr 7, 2010 | 11:46 AM
needhelp92's Avatar
Default tail light problem please help
i just bought a 92 accord, i use it as a comuter car, and is the first honda i have ever owned. so i am very unfamiliar with these cars.
i noticed my tail lights are not working. i checked the fuses and they all look good, the blikers are woring so i know there is power back there.
are the lights that are mounted to the trunk the tail lights?
Old Apr 8, 2010 | 03:19 AM
welcome to the forum. check to see if your ground wires are good. check to see if you have power up to the light bulb. start at the light bulb and work your way back to the fuse. and brake switch, also the blinkers go through the emergency blinker switch. If you go to autozone.com and register, they have a repair section, and wire diagram to help you to do trouble shooting.
crvfan837
Aug 17, 2010 04:01 AM
misterix
Mar 13, 2009 04:24 AM
missa15068
Oct 16, 2008 07:50 AM
johnwiltfongjr
May 23, 2008 05:00 AM
tay829
Aug 10, 2007 11:06 PM
