Turn signal sometimes works ???
Old Feb 27, 2009 | 02:01 PM
broguearcher's Avatar
Default Turn signal sometimes works ???
I posted the other day asking about how to access the right front turn signal bulb in my '98 Civic because it appeared to be bad. However, I'm not so sure now. Sometimes the turn signal will work fine and others it starts to do the characteristic fast flash on the dashboard display that always happens when either the front or rear bulb is out.
When I looked at the right front bulb it was flashing (fast) but seemed a bit dim. The rear bulb was as bright as normal and was also flashing fast.
So, is this a bulb problem? There's a flash switch/fuse located on the fuse panel in most cars right? Could it be going bad? I would expect the left turn signal to have problems as well though and it never does.
thanks!
Old Feb 27, 2009 | 10:13 PM
could be possible blub filament, then flasher. fuse would cause both sides or all to fail. I have had the flasher go bad but all the turn signals flashed fast. Might be a poor ground to the light.
Old Feb 28, 2009 | 02:22 PM
thanks for the help!
Sam
Old Mar 24, 2009 | 02:06 PM
andry's Avatar
Member
Sam, is your problem fixed now? please update us. thanks.
PaulPool89
May 23, 2014 10:57 PM
pyrodork
Sep 6, 2010 02:07 PM
vilfredo
Mar 7, 2009 11:00 AM
mechaincal_nut
Mar 13, 2008 03:25 AM
Eric17
Apr 19, 2006 09:48 PM
