Wanting to remove whole AC unit.....
Old Jan 3, 2008 | 03:33 PM
Isporthonda's Avatar
Default Wanting to remove whole AC unit.....
I need to know if there is any specific way to remove my AC fan and the AC Condenser. Anything would be helpful! Thanks
Old Jan 6, 2008 | 09:03 AM
civicracer1997's Avatar
Default RE: Wanting to remove whole AC unit.....
Its really easy. The law states that you are supposed to depressurize the A/C system into an approved canister to keep the crap from getting into the air cause its bad for the ozone. Most people just disconnect the lines and let it go. I f you do this make sure you dont inhale or get any in your eyes. Let it sit for 10 minutes after you crack the line so that all the crap gets out. Then its just a matter of unhooking some lines, some bolts, some electical connectors, and just pulling everything out.
Old Jan 7, 2008 | 03:38 PM
Thanks man. I didn't have to worry about bleeding the lines cause i had a leak in one of them so all the freon was already out. It looks so much better now though
Old Jan 8, 2008 | 09:01 AM
Makes it much lighter and much easier to work on and makes it much lighter as well. Removing all of the A/C components also made mine run cooler due to the extra flow of cold air over the the header, block, and oil pan.
Old Feb 10, 2010 | 06:11 PM
panda*panda's Avatar
hi there.. I have a leak @ my condenser; think I should still clear out the lines?
Old Feb 18, 2010 | 02:08 AM
break a line and make sure its completely bled.
dnow
Nov 16, 2013 06:07 PM
atrain33
Aug 30, 2011 02:13 PM
kidmikeo
Apr 9, 2008 11:52 AM
kate19
Mar 6, 2007 02:35 AM
kate19
Jan 16, 2007 08:12 PM
