Water on passenger floor
Old Sep 30, 2009 | 09:50 PM
sdjody's Avatar
Default Water on passenger floor
I have noticed water on the floor on the passenger side of my 2004 Accord EX Coupe. Someone mentione it may be a clogged drain from the sunroof that uses the same outlet as the AC drain. Does this correct? If so, can anyone describe an easy fix. Thx.
Old Oct 1, 2009 | 02:22 AM
welcome to the forum. Check the drain tube for obstructions under your car near the fire wall. go to hondaautomotiveparts.com and put in your car info, then to the heater drain hose. Do not put your face under the hose.
Gearshift
Aug 21, 2007 09:43 AM
panaphobic
Mar 27, 2007 11:40 AM
NcTuan07
Jan 25, 2007 11:52 AM
ratzer
Dec 5, 2006 10:52 PM
ztourist
May 30, 2006 06:54 PM
