04 V6 Accord EX coupe window switch
Old Sep 25, 2008 | 08:33 PM
alvinoid's Avatar
Default 04 V6 Accord EX coupe window switch
I am having the same problem that I saw on a threadposted by "drew not u" in june. Unfortunatly no one answered with help except the moderator and he didn't offer any useful info.
Here goes.
Thedrivers side window switch in my 04 accord V-6 coupe was a little loose andfinallybroke one day resulting in me not being able to work my window. Luckily it was up when it failed. I shelled out $170 for a new master control switch and put it in but my my window still doesn't work and now the keyless entry stopped working too.
Do I need to program this thing to work with my keyless entry remote? Why won't my window go up? I also checked the fuse and it looked good.
Old Sep 26, 2008 | 04:55 AM
Default RE: 04 V6 Accord EX coupe window switch
welcome to the forum: hope someone else besides the moderator can help you out. On the drivers window, with a new switch installed, check to see if you have power to your window motor, and if the motor is in working condition.
Old Sep 29, 2008 | 11:53 AM
alvinoid's Avatar
I Don't think anyone else is out three but just in case,I emailed "drew not u" and he informed nme that the master window module needs to be programmed. Here's the procedure for my Accord.
Entering the programming mode cancels all learned keyless remotes, so none of the previously programmedremotes will work.You must reprogram all of the keyless remotes once you are in the programming mode.You must complete each step within 5 seconds of the previous step to keep the system from exitingthe programming mode.
1. Turn ignition switch to ON (II)[/align]2. Press the LOCK or UNOCK button on one of the remotes. [/align] (An unprogrammed remote can be used for thisstep.)[/align]3. Turn ignition switch to LOCK (0)[/align]4. Repeat steps 1, 2 and 3 two more times using the same keyless remote used in step 2[/align]5. Turn the ignition switch to ON (II)[/align]6. Press the LOCK or UNLOCK button the same remote.[/align] Make sure the power door locks cycle to confirmyou are in programming mode.[/align]7. Press the LOCK or UNLOCK button on each remote you want to program.[/align] Make sure door locks cycleafter youpush each remote button to confirm [/align] system has accepted the remote.[/align] 8. Turn the igniton switch to LOCK (0) to exit programming mode.[/align] 9. Test remote(s)[/align]
Old Sep 30, 2008 | 03:02 PM
Thank you alvinoid, you have replied a fix for all others who may have this problem to fix theirs. Not many reply a fix much less reply. Thank you again.
mchavez17
Jun 26, 2015 12:18 PM
nakedkitty15
Mar 22, 2015 08:46 PM
lciambotti
May 31, 2014 03:13 PM
saladfiend
Mar 11, 2011 07:28 AM
wsbkp08
Mar 25, 2009 07:43 PM
