1993 Accord SE - Bolt Size
In trying to replace the fuel filter on my Accord, I removed the vacuum assembly that sits above it and to the passenger side. I didn't realize that the vacuum assembly rests on 2 bolts and can be removed by loosening them. Foolishly, I removed them and dropped and lost one. Lights, mirrors, magnets failed to find it. I've searched online for parts diagrams that might tell me the size of the bolt, to no avail.
I wonder if anyone can tell me the thread, diameter and length of these bolts. They have a 10 mm head on them.
If anyone knows of an online source for parts and parts diagrams, I'd be much obliged to know where to find them.
TIA
TIA
Yeah, I was hoping not to have to futz with that damned vacuum distributor unit; but I pulled it out of the way and pulled out the other bolt. It is an M6 x 24 mm. It is a special bolt with a fixed wide washer to catch and hold the vacuum distributor mounting bracket. I found a large washer and will be sure to have it catch the mounting bracket when it goes back on.
Thought I'd reply just in case anyone is searching in the future for the same bolt in\fo.
Albert190
May 10, 2012 03:49 AM
