2000 Accord cuts off, hard to start, will not idle, intermittent problem
Old Dec 18, 2021 | 01:24 PM
Lawsondtl's Avatar
Default 2000 Accord cuts off, hard to start, will not idle, intermittent problem
I have a 2000 Accord 3.0L Vtec 268,000 miles that has an intermittent problem. It usually occurs when engine is hot. The engine will cut off while idling and is very difficult to start. Sometimes it may start when I hold to gas pedal to the floor, then it will run smoothly when maintaining about 1000 RPM. If I try to let it idle, it will cut off. When driving it, the engine seems to run as if nothing is wrong and has strong acceleration, (but will cut off when I let it idle), then some random time later (15 or 20 minutes) it idles and starts fine as if it never had any problem.
Most recent engine codes when scanned with my cheap scanner:
P0301
P0302
P0304
P0305
P0306
P0300
P1399
P1457
Parts that have been replaced:
All 6 spark plugs, all 6 coil packs, fuel pump, fuel pump relay
Old Dec 18, 2021 | 11:01 PM
Just a guess. Don't know, but the 2000 Accord V6 should have a timing belt
Maybe it has stretched??
Old Dec 19, 2021 | 12:21 PM
Lawsondtl's Avatar
Thanks for your reply. Yes this car does have a timing belt. I have the belt changed at the recommended intervals since it is a "zero clearance" engine. It's not yet due to be changed again, I have read that belts are more prone to breaking, but less prone to stretching compared to chains. I guess it,s possible though.
Thanks!
Old Dec 20, 2021 | 04:49 PM
Dent Man Dave's Avatar
May or may not be relevant but I had a similar problem with a 2001 Volvo S80. I found that a complete cleaning of the throttle body cured it.Also replaced the throttle position sensor.
Old Dec 21, 2021 | 12:33 AM
Like what Dent Man Dave said. Check the throttle. The Idle air control valve. If it has an EGR then check that too.
blutzsr
Jan 16, 2020 09:11 PM
allpr0h
Jul 14, 2009 11:12 AM
abiliojr
Jul 11, 2009 03:31 AM
cravnspd
Nov 20, 2008 12:47 PM
alexk
Feb 1, 2007 11:24 PM
