2001 Honda Accord wheel size help
Old May 2, 2018 | 01:14 PM
tanjid111's Avatar
Default 2001 Honda Accord wheel size help
Hey Guys,
So I own a Honda Accord 2001 4 door, 2.3 liter engine. My original tire size is 195/65R15 and original rim size is 6Jx15 ET55. The offset is 55 and Center bore is 64.1 with a bolt pattern of 4x114.3.
I found a rim for my winter tires. Brand: Cragar Manufacturer's Part Number:83-5641. The size is:
Wheel Diameter: 15 in.
Wheel Width (in): 6.000 in.
Wheel Bolt Pattern (app): 4 x 100mm
4 x 114.3mm
4 x 4 1/2 in.
Backspacing (in): 5.125 in.
Offset: +41.00mm
Center Bore Diameter (mm): 72.00mm
Will this fit my tire?
Old May 6, 2018 | 08:18 AM
I would think it does the offset is a little different which would be the only concern on the front. I have a 2000 Accord that I put a 205 tire on and it looks so much better and seems to ride better also,the only way to know for sure if it will fit the car is try one rim on the car,the tire will definetly fit the rim though.good luck.
Old May 6, 2018 | 01:20 PM
tanjid111's Avatar
Even the center bore is different. Which one affects more? Offset or center bore?
Old May 7, 2018 | 02:36 PM
Offset determines how far the wheel is set out from the hub. Looking again I see your bolt pattern won't match either.
cueball21
Sep 3, 2017 06:19 PM
nmclemore
Sep 2, 2009 10:39 PM
Nate/The/Great
Sep 6, 2007 02:01 PM
tooSQUARED
Jul 15, 2007 01:37 PM
Volk54
Jun 19, 2007 01:42 PM
