2005 Accord, HELP Identifying Parts/Leak Source
Old Sep 9, 2020 | 04:50 PM
AR2020's Avatar
Default 2005 Accord, HELP Identifying Parts/Leak Source
I've been trying to fix a pesky leak on a 2005 Accord, 2.4L VTEC.
This image is of the passenger side of the engine. The oil is getting onto the engine side of the serpentine belt which is throwing it all over the place. The heaviest location is right by this panel with an X on it that is directly adjacent to the oil filter, moving towards the outside of the vehicle. That is the crankshaft just south-east of that panel.
What is that panel and could oil be leaking out of there? Otherwise, I fear its a crankshaft seal leak....
Old Sep 9, 2020 | 08:32 PM
the panel with the "x" is the chain case cover. it has an o ring under it. the crank shaft has a seal, it can also leak. if you are not sure and have the engine apart, change both o ring and the crank seal. then it eliminates the possible oil leaks.
Old Sep 9, 2020 | 10:13 PM
AR2020's Avatar
Thanks so much for the quick reply. Have you ever done the crankshaft seal, is it doable by a DYI guy such as myself?
Old Sep 10, 2020 | 06:21 AM
For a DIYer, I suggest looking at a few youtube videos to get the process and a few tips.
Could make it a whole lot easier knowing what you are about to get into.
Stevebow
Jan 10, 2023 10:54 AM
skunk_ape311
May 19, 2019 06:59 PM
scoostraw
Jan 10, 2019 10:58 AM
PHC
Jul 15, 2013 02:29 PM
XHONDAX
Sep 17, 2006 09:31 PM
