2006 Honda Accord Trouble Starting
Old Jul 13, 2023 | 11:04 AM
Methodem's Avatar
Default 2006 Honda Accord Trouble Starting
I've got a 2006 Honda Accord that has had intermittent trouble starting. New battery, and AutoZone says the alternator, starter, and battery are all fine. I had an engine code for the EVAP Canister Purge Valve which I replaced. We cleared the code and the check engine light hasn't turned back on. When it fails to start, I usually can wait 5 minutes and it will work again. Last time I had someone jump it and it worked, but I'm not sure if that was from the jump or from the "waiting period". It usually has more trouble after I've driven than when I'm starting it up in the morning. Any idea what the problem might be?
Thank you for reading!
Old Jul 13, 2023 | 04:04 PM
What was then code number? Did you blow out the lines before installing the new purge valve?
Old Jul 13, 2023 | 09:34 PM
Questions, ...
Is this a crank, no start?
Or is it a no crank no start?
Each has their own set of circuits that need to be checked
If it is no crank then the starting system needs to be checked
If it is a crank no start then system that keeps the engine running needs to be checked
If it cranks then have you tried to start engine with gear selector in neutral?
Check fuel pressure? Spark? Injectors firing?
What do the fuel trims look like? Short and long term?
Old Aug 24, 2023 | 08:46 AM
TommyHill's Avatar
Any update?
ifi
Aug 31, 2022 08:46 PM
cre2004
Aug 31, 2021 06:00 AM
coryhuddleston
Aug 17, 2016 07:14 PM
chichibella
Nov 19, 2015 07:06 AM
tompav
Nov 15, 2011 07:28 AM
