2007 Honda Accord - Popping noise when braking/taking off
Old Jul 21, 2018 | 09:55 PM
Bandrica's Avatar
Default 2007 Honda Accord - Popping noise when braking/taking off
Hello again,
So my wife's Accord has been making a slight clunking/popping noise on releasing/accelerating or stopping. I took it to a mechanic thinking it might be the CV joint, and he said it was the rack and pinion. When turning the wheel back and forth you can definitely hear a clunking, but I'm a little confused because when she starts or stops, she isn't turning the wheel, so I'm not sure what the R&P would have to do with that. Anything else it could be?
Old Jul 21, 2018 | 11:57 PM
welcome to the forum just info for the rack and pinion,. a bad rack and pinion has tight steering wheel , leaking p/s fluid, grinding noise when steering, burning oil smell. check the following, tie rod, bellow boots, frame mounting bolts. if unsure, take the vehicle to an alignment shop and ask them if they can locate the noise.
Old Jul 29, 2018 | 06:27 PM
Welcome in,this is not a diy ,a pro needs to replace the R&P if that is the problem.
Old Aug 9, 2018 | 10:16 PM
Fr3shxwun's Avatar
Default My car does the same thing!
I have a 2010 Honda Accord and my car has made this noise for awhile and I’ve had it at the dealer multiple times and they couldn’t find the problem. It’s so annoying
Old Aug 10, 2018 | 06:16 AM
Fr3shxwun; welcome to the forum. need more info. when did the noise start, does the noise get louder at any time other than awhile, has there been any maintenance done before the noise started.
Old Aug 10, 2018 | 07:15 AM
Fr3shxwun's Avatar
Acmech— my car has 108,xxx miles. The noise started probably around 80,xxx miles. Or less. It doesn’t get louder. I can tell you that I hear it more in the summer months and Over the winter I didn’t hear it at all. The only maintenance I’ve had done is a wheel hub replaced and tires. Along with oil changes of course.
Nickp87
May 11, 2018 07:37 AM
Andy S
Feb 9, 2014 04:26 AM
QUESTSEEK
Dec 25, 2012 09:55 AM
nplatko
Mar 12, 2010 11:32 AM
pamalsa
Aug 27, 2007 10:07 PM
