2008 Accord V6 CV Help - Hard spill
Old Mar 25, 2019 | 04:57 PM
Justin Grimes's Avatar
Question 2008 Accord V6 CV Help - Hard spill
Hi there!
My GF has an 8th gen '08 Accord V6. This thing has been through a lot. Literally. She's driven it through trees, other cars, everything but the kitchen sink.
Seriously though, it's only half her. The car falls apart all the time. Before we met she had the motor replaced, and since I've known her the left side ball joint came apart and broke a bunch of stuff and now the same thing has happened to the right side of the car.
I'm fixing it for her this time and I've almost got it back together. What I cannot for the life of me figure out is how to get the CV shaft off! All that's left of it is the tranny-side inner joint and boot. The shaft came off in the accident and this is all I've got to work with. The YT vids I've seen show it coming out with a prybar. I tried that but I can't get leverage on it with it sitting on jackstands. From what I can see I'm not even sure if this is the right shaft since it SEEMS to go back further than I can see (like Civic style with a half-shaft+CV shaft that's like 2' long). The internet seems to think it's just a regular CV shaft, but I'm not convinced. What say you, Honda experts!
I'm about $500 in the hole on getting this thing rolling again and I can't wait another week on it. I'll do whatever you guys suggest!
Thank you.
Old Mar 25, 2019 | 11:36 PM
Usually, the CV shaft comes out of the tranny with a pry bar.
But, have heard of some that were a B-itch to get out.
I have seen home made tools to give the Joint a shock to loosen the shaft.
Vise grip on one end. Attached to a slide hammer.
I have seen some use a chisel and a hammer to smack it out
It should not be rusted in
And the only thing holding it in is a metal ring
Just needs enough of a shock or whack to move the ring passed the in-dent/notch
Good luck
Old Mar 26, 2019 | 03:09 AM
mayhem's Avatar
Member
have had that happen also ...once on a ford tempo , I was about to just junk the car I was so frustrated with it finally used a pry bar from whatever side I could worked it out using some penetrating oil and smacking the pry bar with a hammer probably took me 2 hours or so but it did come out
Dusti Rae Baldridge
Nov 12, 2019 10:56 PM
nocim
Dec 12, 2014 02:54 AM
tmounib
Jun 22, 2012 12:05 PM
paulsvail
Mar 26, 2012 10:22 AM
94D16Z6
Nov 26, 2007 10:05 AM
