2016 Honda Accord blower motor not working
Old 09-03-2023 | 08:13 PM
jstephens129's Avatar
Default 2016 Honda Accord blower motor not working
Bought a 2016 accord sport for my daughter at a auction last week and cannot get the blower motor working , I have another 16 accord so I’ve been swapping parts blower , resister and 40 amp fuse so far and all tested good in my other car , what else could it be ? Control panel ? It lights up and works though
Old 09-03-2023 | 08:29 PM
If you apply volts direct to the motor does it work? If not you need to check the ground circuit.
Old 09-03-2023 | 08:41 PM
Yes as I stated I put it in my other accord and it worked
Old 09-03-2023 | 10:46 PM
I'm talking about the one that does not work.
You are wasting a lot of time. We know we have a wiring issue. Check the power and ground to the one that does not work and put your other one back together and let it alone.
I
Old 09-04-2023 | 08:29 AM
I
so you’re saying check the wiring to the blower motor ?
Old 09-04-2023 | 09:37 AM
Yes. Put 12 volts on the motor. Does it run? If so we need to check the ground. What kind of understanding of electricity do you have?
Old 09-04-2023 | 11:22 AM
I have a green and yellow wire to blower motor which one is power yellow ?
Old 09-04-2023 | 11:27 AM
I can put negative and positive of my drill battery and it works but nothing while connecting to blower through factory wiring and doing same thing , I tried running power from drill battery and also ground to wires while connected and it does nothing , also took ac control unit out and it works in my other accord
Old 09-04-2023 | 01:22 PM
You have a bad ground.
  #10
Old 09-04-2023 | 01:41 PM
Do you know what grounds control blower motor so I can check them ?
Quick Reply: 2016 Honda Accord blower motor not working
