2016 Honda Accord blower motor not working
Old Sep 4, 2023 | 09:03 PM
  #21
jstephens129's Avatar
Yes I’m aware , I’m looking for someone who works on these everyday to help me I’ve done allot of mechanical stuff myself engine swaps etc but the logical reason it doesn’t work doesn’t make sense I’ve tested everything only thing I haven’t done is disable the fuse box up front and test the wire coming out the 40 amp fuse
Old Sep 5, 2023 | 07:25 AM
  #22
I've fixed many blowers but my approach is with testing. I need an electrical diagram. You may need to load test the power circuit. What all is powered by that 40 amp fuse? Do you have a diagram?
Old Sep 5, 2023 | 08:23 AM
  #23
No I do not I was hoping the forum would , if I had a wiring diagram I wouldn’t be here lol
Old Sep 5, 2023 | 10:41 AM
  #24
Look for blower motor relay in engine bay fuse box. Apparently ground is provided thru power transistor which determines the speed of the blower fan motor.
Do you know how to test a relay/socket?? Check fuses.
Old Sep 5, 2023 | 11:02 AM
  #25
there is only one 40 amp fuse that indicates blower motor and it was first thing I checked and it’s good
Old Sep 5, 2023 | 04:05 PM
  #26
So does the HVAC control unit turn on the power transistor to turn on the fan?
Does the blower motor relay turn on which gives the blower motor the power to run?
Did you check the blower motor relay?
Is there power at the fuse when the blower fan is turned on?
Old Sep 5, 2023 | 05:48 PM
  #27
you didn’t read my reply did you lol , there’s no relay
Old Sep 5, 2023 | 07:10 PM
  #28
The relay is near the 40 amp fuse.
Go to 1 minute 30 seconds of this video and you'll find your relay that's not there.
Old Sep 5, 2023 | 07:42 PM
  #29
[QUOTE=grcauto;42956]The relay is near the 40 amp fuse.
[/QUOTE
I’ll check it out tommorow and report back but it’s listed as something else , appreciate the help
Old Sep 6, 2023 | 05:31 PM
  #30
I'm going out on a short limb and say this relay did the trick.
