2017 accord - clearing codes
Old Oct 13, 2019 | 05:20 PM
Jake2h's Avatar
Question 2017 accord - clearing codes
Newbie here. 2017 Accord Touring Hybrid. Had my first oil change/tire rotation. The garage checked inflation when they rotated. I’m getting a low tire pressure warning after they reset the oil change mileage. After 3-4 starts I’m still getting the warning. Know there is no under-inflation. How do I clear the warning without going to a dealer to reset it? Am I able to reset it myself? Thanks, Jake
Old Oct 13, 2019 | 08:29 PM
Rotating the tires could have set off the TPMS warning light
If it doesn't turn off after running for a while then consider that it maybe the TPMS unit.
Which one? IDK.
Good luck
Old Oct 14, 2019 | 01:00 AM
welcome to the forum. few ways to turn off the tpm light drive 30 cumulative miles between 30-65ph. or check to the left lower side of your dash (left of the steering wheel) to see if there is a tire pressure monitor reset button push to reset, or if you have a touch screen on the steering wheel button, press Menu, select customized settings, select tpms califration, select Initialized, select yes, press Menu to Exit. or go back to your tire shop that rotated the tires and have them reset the tpm.
B0B
Dec 15, 2019 10:07 PM
Akord
Jul 16, 2017 04:31 PM
PCollen
Nov 30, 2016 03:51 AM
advait
May 24, 2013 08:51 AM
Marc
Nov 22, 2008 06:05 AM
