2017 accord idle rough when brake engaged
Old Mar 31, 2019 | 11:28 AM
Buffalobill25's Avatar
Default 2017 accord idle rough when brake engaged
On my 2017 accord I noticed when I'm at a stop light my car idles rough and rpms drop a little bit. If I put the parking brake on in drive and take my foot off the brake it idles smooth as can be and the rpms rise up. What is causing this??
Old Mar 31, 2019 | 06:51 PM
Brake booster???
Old Mar 31, 2019 | 11:22 PM
if your car is under warranty, take it to the dealer to have it fixed. also could be a possible vacume line leak.
Old Apr 1, 2019 | 05:13 AM
Is there a way I can test this on my own to see if it is the brake booster? Dealership around here never wanna fix the problem. 🙄
Old Apr 1, 2019 | 06:14 PM
Wouldn't try until the dealership has had a look
Talk with tech if possible so you get as much info about the problem
Take off hose on brake booster and plug it.
Run engine and hit brakes to see if same thing happens.
If idle stays the same then brake booster is suspect
If idle does same as before then not the brake booster
But, brake booster is only a guess
Old Apr 1, 2019 | 10:32 PM
if you touch anything and leave any hand prints, disturbed dirt / dust on any hose, the dealer will say you tampered with it, therefore you caused the rough idle. make sure you clean any trace of you touching anything under the hood before taking it to the dealer if you touch or remove any lines.
Old Apr 1, 2019 | 11:16 PM
So, true.
This is why you should not touch anything until the dealership has had a go at it.
Let them fix it under warranty
fourtrax
Jul 27, 2019 05:18 PM
mayhem
Jul 2, 2019 12:32 PM
Buffalobill25
Jun 3, 2019 08:12 PM
Squashua
Aug 10, 2010 02:28 AM
Ltt
Jun 10, 2009 03:39 AM
