91 accord with weird tranny issue
Old Nov 4, 2009 | 10:47 PM
refman1970's Avatar
Default 91 accord with weird tranny issue
The other day the S light came on and the tac started acting radically. the car is running but I have to keep a key in the shifter release slot and shift manually any ideas? In advance thanks
Old Nov 7, 2009 | 03:22 AM
welcome to the forum. the transmission control module (TCM) may be going out. You might try to see if you can get the code to get closer to the cause of the problem.
try this site for more info
http://autorepair.about.com/library/a/1i/bl809i.htm
Old Nov 30, 2009 | 11:45 AM
rebelagent's Avatar
I'm no expert but when my S light went on all I needed was my sensor replaced.
I also had a few vacuum leaks that caused my RPM to go off a bit. All it was was a few busted hoses. Replaced and fixed it. Does the car sound like it's going then goes softly then goes then goes softly? If so I think it's a vacuum link and entirely different from the S light.
Old Dec 1, 2009 | 08:03 AM
refman1970's Avatar
Default I fixed it
I took the advice to have the Transmission computer checked out. It had a burned out resistor. I found a place in east TN that repaired it for $60 that is if you purchase it on Ebay otherwise it would cost $160. Works fine now.
Thanks all
sunkissed64
Feb 13, 2013 08:43 AM
husky22811
Nov 3, 2011 01:52 PM
baritus
Feb 26, 2010 02:27 AM
JMac
Feb 10, 2010 04:35 AM
emmyloulou
Aug 6, 2009 03:29 AM
