95 Lx AC water prob!!! Help
Old 08-30-2009 | 11:42 AM
Futrtrpr's Avatar
Default 95 Lx AC water prob!!! Help
When the AC is on I hear weird noises coming from the vents, whenever I turn Right, water rushes out just above the gas pedal(all over my foot) Whenever I turn Left water floods out on the passenger side in the same general area...Thanx in advance!!!!
Old 08-30-2009 | 12:40 PM
welcome to the forum. Check to see that your drain hose has not stopped up with "crud" leaves,mold,sand,dirt,insects. from under the car there will be a drain hose that closes up at the end for water drain out no bugs in. squeeze it end to end do not look up into it, junk may drain/ fall out. If no drain, it may be clogged. The water is the condensation from the outside moisture that cannot drain out (plugged drain) .
Old 08-30-2009 | 12:44 PM
Futrtrpr's Avatar
Thank you sir!!!
Old 08-30-2009 | 12:51 PM
go to hondaautomotiveparts.com and put your car info in, and go to a/c cooling unit, item 5 is the drain hose. be safe when you jack your car up, use good jack stands and chock your wheels. No need to call me sir please.
Old 08-30-2009 | 12:53 PM
Futrtrpr's Avatar
Habbit...Will do!!
longels
04-27-2011 12:48 PM
hondaaccordsohcvtec
03-14-2011 11:56 AM
civic2017
09-21-2008 01:18 PM
civic2017
08-14-2008 10:01 PM
unclecracker
12-09-2007 07:17 PM
