95 Lx AC water prob!!! Help
Old Aug 30, 2009 | 10:42 AM
Futrtrpr's Avatar
Default 95 Lx AC water prob!!! Help
When the AC is on I hear weird noises coming from the vents, whenever I turn Right, water rushes out just above the gas pedal(all over my foot) Whenever I turn Left water floods out on the passenger side in the same general area...Thanx in advance!!!!
Old Aug 30, 2009 | 11:40 AM
welcome to the forum. Check to see that your drain hose has not stopped up with "crud" leaves,mold,sand,dirt,insects. from under the car there will be a drain hose that closes up at the end for water drain out no bugs in. squeeze it end to end do not look up into it, junk may drain/ fall out. If no drain, it may be clogged. The water is the condensation from the outside moisture that cannot drain out (plugged drain) .
Old Aug 30, 2009 | 11:44 AM
Futrtrpr's Avatar
Thank you sir!!!
Old Aug 30, 2009 | 11:51 AM
go to hondaautomotiveparts.com and put your car info in, and go to a/c cooling unit, item 5 is the drain hose. be safe when you jack your car up, use good jack stands and chock your wheels. No need to call me sir please.
Old Aug 30, 2009 | 11:53 AM
Futrtrpr's Avatar
Habbit...Will do!!
longels
Apr 27, 2011 11:48 AM
hondaaccordsohcvtec
Mar 14, 2011 10:56 AM
civic2017
Sep 21, 2008 12:18 PM
civic2017
Aug 14, 2008 09:01 PM
unclecracker
Dec 9, 2007 06:17 PM
