96 Accord Vtec - white smoke at start up
Old Aug 26, 2013 | 06:32 PM
FriendshipUSA's Avatar
Default 96 Accord Vtec - white smoke at start up
I have a 1996 Accord V-tec. It sometimes develops white smoke when it first starts, then, it goes away after the car has run a short period. Sometimes the white smoke is allot and other times there is absolutely no smoke. I do know the car has over heated (used car) based on what I found after I replaced the head with a rebuilt one. However the new rebuilt head did not fix the problem. The car continues to have intermittent white smoke at startup. There is no water in oil. I occasion have to refill the coolant from time to time (but all the time).
Observations: When the original head was removed I noticed cylinder-1 had a difference in residue in head's underside. This suggested the coolant leak is into cly-1. I replaced the head with a rebuilt one. I also changed the Oil and there was not water in the oil. Could the problem be in the intake manifold? at the cylinder 1 intake there is a coolant feed area. Perhaps a crack had developed within the inner wall between the coolant area and the cly-1 intake chamber. Has anyone seen this type of problems? Any ideas?
I plan to work on the car this weekend and will start with a compression test. Any help in diagnosing the cause is greatly appreciated. (Note: the car runs great after the white smoke clears)
Thanks
Old Aug 27, 2013 | 05:56 PM
lowlife9's Avatar
overheating could have caused the engine block to warp if that's the case replacing the head or head gaskit won't fix the problem. you need to do a compression test to find out the problem.
hadden
Aug 7, 2013 10:36 AM
grantlyn513
Apr 1, 2013 11:54 AM
zacary
Feb 15, 2008 05:28 PM
97civic123
Sep 15, 2006 04:23 AM
tdfaile
Sep 7, 2006 06:46 PM
