ABS woes
Old Jun 23, 2018 | 01:20 PM
caldwj's Avatar
Default ABS woes
HI, I replaced a bad left front hub bearing on my '07 Accord. The new bearing is correctly installed with the magnetic seal facing in (towards ABS sensor in knuckle casting). ABS worked correctly prior to hub bearing replacement. Now when I hit brake, ABS immediately kicks in. The wheel sensor was replaced as it was damaged when removed to allow bearing to be pressed in. Checked the cable connections, all good. I don't have a way of pulling codes to tell what's going on. Any suggestions before I go to a shop and admit defeat? Stumped
David Kidd
Jul 2, 2019 05:53 AM
toph
Jul 27, 2017 08:11 AM
Thelandlordsmm
Aug 5, 2009 09:27 AM
proff
Feb 12, 2007 01:00 AM
DadDog83
Nov 26, 2006 09:53 PM
