accord ecu problems
Old Mar 24, 2011 | 06:41 AM
hmcfarlane's Avatar
Default accord ecu problems
my 2002 vtec sport kicks back when u push it over 3500 rpm then has irratic idling and the engine light comes on the fault code is p1259 vtec error i was told my ecu is broke ,car is still running ok need second opinion
Old Mar 24, 2011 | 11:40 AM
Welcome to the forum,You need to get the real OBDII CODES read. The 'blink' codes are archaic
and tell little. You can get them read at any Advance auto parts or Auto zone.
Old Jul 9, 2012 | 10:11 PM
Honda333's Avatar
Hi all! Might have the same problem as above post. I have a 2001 Honda Accord V6 with roughly 128K miles. Recently I keep getting the code of P1259 01/01 (Fault: 01, Pend: 00). I've changed the oil and the oil levels have remainded at full. I have been using Full synethic since I bought the car new. Coolant level sits at correct level and has been changed about 6 months ago. I recently used Seafoam in the engine and gas after I first incurred the above code reading. I know the P-code is a V-TEC system fault which relates to oil pressure or Solenoid problems. Any further guidance you can assist me with? Thanks!
Old Jul 10, 2012 | 08:59 PM
lowlife9's Avatar
did you try cleaning out the VTEC solenoid if the metal screen inside gets clogged up it will give you a malfunction . ??? i don't feel like searching for the accord diy i will leave that up to you but here is a 2001 civic diy as a reference. http://www.civicforums.com/forums/11...e-up-mods.html
Old Jul 11, 2012 | 12:00 PM
Honda333's Avatar
Great link and info lowlife9 - Thanks. I intend to see if I can do all of those maintenance items because I have seen a fuel mileage decrease over the last few years as well. I'm searching all over for the Vtec Solenoid but can't seem to find it. Most of the videos and pictures out on the web are of the 4cyl engine. I have the V6 3.0 - I took all the decorative caps off the engine still no sign of the part. Would you happen to know where it is located? From what I understand it looks like a smaller silver oil fuel filter or it is different on this car?
lifethinker
Apr 18, 2014 03:34 PM
thirdeye46n2
Jul 18, 2007 12:26 PM
joelogan25
May 23, 2007 10:20 AM
rpankau
Dec 30, 2006 02:12 PM
gsrhatch
Dec 4, 2005 03:21 PM
