Brake lights out. 2005 Honda Accord
Old Mar 12, 2013 | 10:05 AM
Marshall Maloney's Avatar
Default Brake lights out. 2005 Honda Accord
All three brake lights have gone out. I have checked bulbs, fuses, and relays to figure out the problem. Nothing is seeming to work. Also not sure if it is connected, the backlight to the radio went out at the same time. All other lights and functions of my car are working perfectly. Anybody have any ideas?
Old Mar 12, 2013 | 01:55 PM
Welcome in.Check the brake light switch - normally situated inside the car under the dashboard adjacent to the brake pedal. Check that the electrical connector is still attached and that there is a voltage supply to one of the pins. Disconnect the connector and using a multimeter on the resistance setting, check that the brake light switch operates as expected when the switch button is depressed
Old Mar 12, 2013 | 02:09 PM
lowlife9's Avatar
do you have an aftermarket radio if so do not connect the illumination wire this can cause electrical problems.
Old Apr 25, 2013 | 05:24 PM
hondatech's Avatar
Default brake lights
Check your brake switch. Does your shift lever move out of park? If not you got an electrical problem. And your backlight on your radio is caused by a circuit problem in the radio if it is stock radio. Common problem. Depending on your warranty you can get it fix. If not bitch out American Honda constantly and they might be able to cover some of the cost. Works most of the time.
Old Apr 26, 2013 | 06:12 AM
welcome to the forum hondatech. good advise with american honda.
Old Apr 26, 2013 | 09:40 AM
Be interested in knowing if it was the brake switch.
JennyBoo311
Mar 4, 2021 07:06 PM
cookiekare
Sep 23, 2019 11:27 PM
Andrew Solomon
Jan 1, 2015 08:03 AM
Barletter
Jul 3, 2014 12:47 PM
diamonddelts
Nov 1, 2009 11:22 AM
