Check Engine Light
Old Sep 10, 2006 | 11:23 AM
whermanov's Avatar
Default Check Engine Light
My '98 Honda Accord (90,000 miles) has produced a diagnostic code related to emissions. Car is running perfect and I hate to spend the money on all the possible causes of this "code". What consequences do I face if I ignore this problem and just continue to drive? Is there a cheap / simple remedy to such an emissions related issue?
Old Sep 11, 2006 | 04:28 PM
timgun10's Avatar
Default RE: Check Engine Light
I just bought a 99 Accord w/ 115k and the check engine light came on. They said the knock sensor was broken which was about $300 at Firestone.
Old Sep 20, 2006 | 09:29 PM
marcin's Avatar
The accords have a common problem with EGR valve which isrelated to emission. I had the same thing with my Camaro, I`ve been driving like that for 4 years,itburns a bit more gas that`s all... but make sure that `s the problem
Old Sep 22, 2006 | 09:41 PM
alexhonda's Avatar
i had the same problem and i had the egr fixed under warranty i had about 70K on my 2000 accord. it is somthing to do with the hole in the unit getting clogged
Old Sep 23, 2006 | 04:16 PM
beefyangus612's Avatar
if you dont know what the code, or the reason of your check engine light then you can bring it to not all but almost any garage and they can dignose your problem. onece you know what the problem is, then you would knwo weather or not it is safe to drive with
fyah17
Dec 22, 2012 03:03 PM
samuel_gatech
Nov 4, 2009 04:46 AM
papic03
Mar 6, 2007 09:17 PM
silverbullet
Feb 19, 2007 08:26 PM
cpatd
Nov 13, 2006 02:03 PM
