Check Engine Light PO441
Old May 23, 2009 | 10:46 AM
fuzznick's Avatar
Default Check Engine Light PO441
I have a Honda Accord 1997 , Check engine light is on and code is P0411, can this be fixed, my mechanic changed the gas cap it did not help , and is there a recall on this?
I just got my ignition coil changed this does not have anything to do with it, does it?
Old May 24, 2009 | 08:19 PM
p0411 Secondary Air Injection System Incorrect Flow. check for the following, dirty, poor or loose connections at the air control valve, vaccum control solenoid, and ECM. Might want to get yourself a helms service manual to assist. If you need to look up the parts, go to hondaautomotiveparts.com and place the info in to find the diagram to your car parts. don't change anything until you do the troubleshooting.
fyah17
Dec 22, 2012 03:03 PM
samuel_gatech
Nov 4, 2009 04:46 AM
silverbullet
Feb 19, 2007 08:26 PM
cpatd
Nov 13, 2006 02:03 PM
whermanov
Sep 23, 2006 04:16 PM
