check engine light trouble
Old Mar 3, 2011 | 11:54 PM
gerardo's Avatar
Unhappy check engine light trouble
i got a 1990 honda accord obd1 and i am having trouble figuring out the problem. Am getting code 43 fuel suply system.I already changed o2 sensor twice ,new fuel pump,new gas cap,spark plugs cables distributor cap,main relay.also in the morning when i start the car it will idle so low that it will turn off i got to give it gas for about 20-30 secs then it will work fine. any suggestions please help.....!
Old Mar 4, 2011 | 05:49 AM
welcome to the forum. When was the fuel filter on the firewall last changed. have you checked the fuel pressure at the fuel rail. is your 02 sensor Honda or aftermarket?
Old Mar 10, 2011 | 12:27 AM
gerardo's Avatar
Default check engine light trouble
thank you acmech52 for replying .and i changed the fuel filter twice before i put a new fuel pump ,the pressure on the fuel rail was31 psi with new fuel pump and i had no pressure loss. and the o2 sensor i changed twice . the one i have on right now is denso.the light came off for about 2 weeks and came back on but the car runs good but cant pass smog chk and starts ****y in the morning while its cold
Old Mar 10, 2011 | 02:18 AM
just for info: If the O2 sensor is an aftermarket, even if it is like the factory denso, it will cause the light to come on. some last up to 3 mos. on the first start of the day running rough idle, is the idle cut off clean.
Old Mar 11, 2011 | 12:53 AM
gerardo's Avatar
how can you tell if the o2 sensor is aftermarket denso. also if it was the o2 sensor would it be showing code 43 or another code
Old Mar 11, 2011 | 02:27 AM
If you purchased the O2 sensor from any place other than Honda, it is an aftermarket. code 43 also could be dirty fuel injector or bad injector resistor. Do you have a Honda manual to assist you.
Jordan McKenzie
Jan 2, 2014 10:27 PM
fyah17
Dec 22, 2012 03:03 PM
captmoto
Sep 4, 2010 10:45 AM
samuel_gatech
Nov 4, 2009 04:46 AM
whermanov
Sep 23, 2006 04:16 PM
